Issue logging into cesium from UE5.5.2
Hi
when i click the 'connect to cesium ion from within UE I get the following error:
Missing required OAuth 2.0 parameter “scope”
I’ ve tried the 'open in webbrowser again, copied th clipboard, rebooted UE, rebooted the PC, but still the same problem… any ideas please?
I CAN login to cesium ion independently just fine, as i can into this forum… but not from UE
OK just pasted the urL into Edge browser instead of chrome and I can login fine… but UE doesn’t see i’ve logged in and continues to wait for connection…
Same problem over here.
Sorry for the inconvenience! We briefly published a version with this bug to Fab.com, but canceled it long before it actually became available to users (or so we thought). We’ve now published a new version with a fix, so please try upgrading and see if that fixes the problem for you. You should get v2.13.1 (look in the lower-right corner of the Cesium panel within the Editor to find the version).
Tnx for the fast reply!
It worked
sorted thanks :slight_smile:
facing same issue with 2.24.1
The same problem also showed up in version v2.27.0
@Kevin_Ring ,Can you help me how to solve this problem?
