Due to the deprecation of old terrain provider tools, I am attempting to upgrade to the new Cesium versions to use the new terrain tools. However, when running my Visual Studio app, I get an Access Is Denied error that prevents Cesium from starting up. This error comes in at Cesium 1.35+. For lower versions 1.29-1.34, my app works.
Heres the error in Cesium 1.35:
Line:521
Char:4075
Error: 'Access is denied.'
Code: 0
URL: file:///C:/Cesium/Build/Cesium/Cesium.js
Addtionally, on the viewer:
Error: Access is denied.
at d.load (file:///C:/Cesium/Build/Cesium/Cesium.js:521:4075)
Are you aware of a security type change that was not covered in the change log? I am currently thinking it is an issue with internet explorer and some sort of security settings.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>Test</title>
<script src="../Build/Cesium/Cesium.js"></script>
<style>
@import url(../Build/Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
</script>
</body>
</html>
Interested in generating a globe with terrain for an aircraft simulation/visualization. As of now, I don't believe there is another way to generate terrain. GoogleEarthEnterprise and other URLs that worked for versions 1.29-1.34 dont appear to be active anymore.
Issue starts at Cesium 1.35, but can verify it happens at 1.4,1.42, and 1.53
Windows 10
Internet Explorer 11
Visual Studio 2017
Thank you for your help, it is very appreciated.
