I want to show Line of Sight on 3D buildings with color format projection instead of lines, where human can visible over the buildings in that area.
var thetaMax = 360; //bearing in degrees
var dTheta = 10;
var R = 5000; // distance in meters
var centerLLH = Cesium.Cartographic.fromDegrees(-75.5966, 40.0386 , 0.0);
var centerXYZ = Cesium.Cartographic.toCartesian(centerLLH);
// We'll need the transformation from local coordinates to Earth-Centered, Earth-Fixed
var enuTransform = Cesium.Transforms.eastNorthUpToFixedFrame(centerXYZ);
for (var theta = 0; theta < thetaMax; theta += dTheta) {
var dX = R * Math.cos(Cesium.Math.toRadians(theta)) ;
var dY = R * Math.sin(Cesium.Math.toRadians(theta));
var limitENU = new Cesium.Cartesian4(dX, dY, 0.0, 1.0);
// Transform point in local coordinate system (East-North-Up) to ECEF
var limitECF = new Cesium.Cartesian4();
limitECF = Cesium.Matrix4.multiplyByVector(enuTransform, limitENU, limitECF);
var glowingLine = viewer.entities.add({
name : 'Ray at ' + theta + ' degrees ENU',
polyline : {
positions : [
centerXYZ,
limitECF
width : 1,
material : Cesium.Color.ORANGE.withAlpha(0.5),
var centerEntity = viewer.entities.add({
position: new Cesium.ConstantPositionProperty(centerXYZ),
point: {
viewer.zoomTo(centerEntity);
I want to show Line of Sight on 3D buildings with color format instead of line, where human can visble over the buildings in that area
cesuim 1.39, windows 10
