Thanks for the link! I was messing around with point primitives earlier and wasn't able to get it to do exactly what I want so went ahead and coded it up with entities but even with only 1000 points it is too slow.
I need to draw circles around points and want them to be a certain radius that stays constant with respect to the earth even if you zoom in or out. When I was using primitives the number of pixels would stay the same on zooming in or out so the radius of the circle if you were to measure it in meters was changing. Is there any way to do this with point primitives?
This code I wrote does what I want but it uses entities. If you post it here and run it it should work: https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Hello%20World.html&label=Showcases
var viewer = new Cesium.Viewer('cesiumContainer',{
sceneMode : Cesium.SceneMode.SCENE2D
var elliproperties = new Cesium.EllipseGraphics({
semiMajorAxis : 7585,
semiMinorAxis : 7585,
fill : true,
// distanceDisplayCondition : new Cesium.DistanceDisplayCondition(0,1000000),
material : Cesium.Color.RED.withAlpha(0.5)
function updateSize(size){
for (var i=0; i<towercollection.values.length; i++){
towercollection.values[i].ellipse.semiMajorAxis = size;
towercollection.values[i].ellipse.semiMinorAxis = size;
var towercollection = new Cesium.EntityCollection();
var promise = Cesium.GeoJsonDataSource.load(‘https://raw.githubusercontent.com/BootstrapB/CelltowersCesium/master/features.geojson’);
promise.then(function(dataSource) {
//viewer.dataSources.add(dataSource);
//Get the array of entities
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
var pos = entity.position._value;
var tower = viewer.entities.add({
name : 'Tower' + i,
show: true,
position : pos,
ellipse: elliproperties
towercollection.add(tower);
}).otherwise(function(error){
//Display any errrors encountered while loading.
window.alert(error);
var t1 = viewer.entities.add({
show: true,
position : Cesium.Cartesian3.fromDegrees(-88,40),
towercollection.add(t1);
var t2 = viewer.entities.add({
show : true,
position : Cesium.Cartesian3.fromDegrees(-88.5,40.5),
towercollection.add(t2);
var options = [{
text : 'GLN 1 dB',
onselect : function(){
updateSize(7585);
text : 'GLN 3 dB',
updateSize(5220);
text : 'GLN 5 dB',
updateSize(3500);
text : 'HPR 1 dB',
updateSize(12010);
text : 'HPR 3 dB',
updateSize(4275);
text : 'HPR 5 dB',
updateSize(4275);
text : 'TIM 1 dB',
updateSize(1130);
text : 'TIM 3 dB',
updateSize(690);
text : 'TIM 5 dB',
updateSize(690);
Sandcastle.addToolbarMenu(options);
