I’ve been trying to lock the camera so LMB dragging will only spin the Earth left and right around the equator, without much luck. Any ideas?
The camera object is available, but I’m not sure what to change to snap it in place, e.g. maybe something as simple as constantly setting camera.position.y = 0 on update
I have a suspicion that it is easy to do if you know the internals of Cesium
Gerald
Hi Gerald,
I apologize for the late response. The camera system has been undergoing some major changes. You can check out at the camera branch or pull request #282 if you’re interested. Unfortunately, there isn’t a simple way to lock the camera to rotating around the equator, but, as you mentioned, you can try modifying the camera on update. Here is what you would need to do:
camera.position.z = 0.0; // set the camera to be in the xy-plane
camera.up = Cartesian3.UNIT_Z; // set the up direction to point north
camera.direction = camera.position.negate().normalize(); // set the view direction to the center of the earth
camera.right = camera.direction.cross(camera.up) // compute the right direction
Let me know if this helps.
Dan
Hi Dan,
Thank you for your response. I’m not allocated time to work on our Cesium based project right now, but I’ll let you know how well this works (and check out the branch) when I get back on it.
Hopefully it’ll be sooner than later
Gerald
