我想替换CESIUM为Unity提供的地球海面,但是大多数用于制造海洋的插件都是制造的平面,不可能将它们完美地安装到地球模型中
Translated:
I want to replace the earth sea surface provided by CESIUM for Unity, but most of the plugins for making oceans are made planes and it is not possible to fit them perfectly into the earth model
You could probably use those ocean plugins at ground level, where the curvature of the Earth is less obvious. Are you trying to replace the oceans from a view that is farther away?
I found that cesium for ue can simulate the ocean, is this implementation planned?
It’s not on our current roadmap, no. If the water effects are something that you’d like in Unity, I can write a Github issue for it as a feature request.
Thank you, there is a seaside scene needs, now can only use the plane as a temporary effect
Hello, please ask what plugin you are using now to make the ocean effect, the ocean I am making now is not very ideal
