I used FME to convert COLLADA to 3DTILES, but I can’t show it when I load it into cesium.
I generated a 3dtiles document in order to test the normal display in cesium. I suspect the coordinate system is a problem, but I do not know how to solve it.
If you can make it appear properly, I hope you can help me solve this problem. thanks a lot!
tileset.json (446 Bytes)
data0.b3dm (31.4 KB)
