I am using cesium to display placemarks on airport maps with IE11. Though it works fine on my computer, the placemarks don't display on many others and cesium is very slow on those computers.
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version. -->
<meta http-equiv="X-UA-Compatible" content="IE=11">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>AGS World</title>
<script src="../Build/Cesium/Cesium.js"></script>
<style>
@import url(../Build/Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
Cesium.BingMapsApi.defaultKey = ‘’;
imageryProvider : new Cesium.ArcGisMapServerImageryProvider({
url : ‘https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer’
baseLayerPicker : false,infoBox : false, selectionIndicator : false, animation: false,fullscreenButton: false, timeline: false
viewer.render()
var moving ;
var mousePosition = new Cesium.Cartesian2();
var mousePositionProperty = new Cesium.CallbackProperty(function(time, result){
var position = scene.camera.pickEllipsoid(mousePosition, undefined, result);
var cartographic = Cesium.Ellipsoid.WGS84.cartesianToCartographic(position);
cartographic.height =0;
return Cesium.Ellipsoid.WGS84.cartographicToCartesian(cartographic);
}, false);
var scene = viewer.scene;
var dragging = false;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(
function(click) {
var pickedObject = scene.pick(click.position);
if (Cesium.defined(pickedObject) ) {
moving = Cesium.defaultValue(pickedObject.id, pickedObject.primitive.id);
dragging = true;
scene.screenSpaceCameraController.enableRotate = false;
Cesium.Cartesian2.clone(click.position, mousePosition);
moving.position = mousePositionProperty;
Cesium.ScreenSpaceEventType.LEFT_DOWN
function(movement) {
if (dragging) {
Cesium.Cartesian2.clone(movement.endPosition, mousePosition);
var ellipsoid = viewer.scene.globe.ellipsoid;
var cartesian = viewer.camera.pickEllipsoid(mousePosition, ellipsoid);
var cartographic = ellipsoid.cartesianToCartographic(cartesian);
var longitudeString = Cesium.Math.toDegrees(cartographic.longitude).toFixed(7);
var altitudeString ='0';
var latitudeString = Cesium.Math.toDegrees(cartographic.latitude).toFixed(7);
top.document.title= '<EVENT>coordinates</EVENT>' +'<longitude>' + (longitudeString).slice(-20) + '</longitude>' +
'<latitude>' + (latitudeString).slice(-20) + '</latitude>'+
'<altitude>' + (altitudeString).slice(-20) + '</altitude>'+
'<placemark>' + moving.id + '</placemark>';
Cesium.ScreenSpaceEventType.MOUSE_MOVE
function(click) {
if(dragging) {
dragging = false;
scene.screenSpaceCameraController.enableRotate = true;
moving.position = scene.camera.pickEllipsoid(click.position);
else {
var cartesian = viewer.camera.pickEllipsoid(click.position, ellipsoid);
top.document.title= '<EVENT>clicked</EVENT>' +'<longitude>' + (longitudeString).slice(-20) + '</longitude>' +
'<altitude>' + (altitudeString).slice(-20) + '</altitude>';
Cesium.ScreenSpaceEventType.LEFT_UP
var entity_coordinates = viewer.entities.add({ id:'coordinates', label : { show : false, showBackground : true, font : '14px monospace', backgroundColor : Cesium.Color.ROSYBROWN , horizontalOrigin : Cesium.HorizontalOrigin.LEFT, verticalOrigin : Cesium.VerticalOrigin.TOP, pixelOffset : new Cesium.Cartesian2(30, -30) } }); handler = new Cesium.ScreenSpaceEventHandler(scene.canvas); handler.setInputAction(function(movement) { var cartesian = viewer.camera.pickEllipsoid(movement.endPosition, scene.globe.ellipsoid); if (cartesian) { var cartographic = Cesium.Cartographic.fromCartesian(cartesian); var longitudeString = Cesium.Math.toDegrees(cartographic.longitude).toFixed(7); var latitudeString = Cesium.Math.toDegrees(cartographic.latitude).toFixed(7); entity_coordinates.position = cartesian; entity_coordinates.label.show = true; entity_coordinates.label.text = 'Lon: ' + (' ' + longitudeString).slice(-20) + '\u00B0' + '\nLat: ' + (' ' + latitudeString).slice(-20) + '\u00B0'; } else { entity_coordinates.label.show = false; } }, Cesium.ScreenSpaceEventType.MOUSE_MOVE);
var pinBuilder = new Cesium.PinBuilder();var entity = viewer.entities.add({name : ‘arp_$1’,id : ‘arp_$1’,position : Cesium.Cartesian3.fromDegrees(-69.38873056,77.48865), label : {text : ‘QAANAAQ’, font :‘16px tahoma’, showBackground :true, backgroundColor : Cesium.Color(0.165, 0.165, 0.165, 1), translucencyByDistance : new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 1.0), verticalOrigin : Cesium.VerticalOrigin.TOP, distanceDisplayCondition: new Cesium.DistanceDisplayCondition(0.0 ,8000.0), }, billboard : { image : ‘http://localhost/ags/cesium/apps//blue-dot.png’, verticalOrigin : Cesium.VerticalOrigin.BOTTOM, scaleByDistance :new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 0.0), }});
var pinBuilder = new Cesium.PinBuilder();var entity = viewer.entities.add({name : ‘rwy_$1’,id : ‘rwy_$1’,position : Cesium.Cartesian3.fromDegrees(-69.40436944,77.49083056), label : {text : ‘Runway 18 - LDA start point’, font :‘16px tahoma’, showBackground :true, backgroundColor : Cesium.Color(0.165, 0.165, 0.165, 1), translucencyByDistance : new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 1.0), verticalOrigin : Cesium.VerticalOrigin.TOP, distanceDisplayCondition: new Cesium.DistanceDisplayCondition(0.0 ,800.0), }, billboard : { image : ‘http://localhost/ags/cesium/apps//grn-pushpin.png’, verticalOrigin : Cesium.VerticalOrigin.BOTTOM, scaleByDistance :new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 0.0), }});
viewer.camera.flyTo({ destination : Cesium.Cartesian3.fromDegrees(-69.38873056,77.48865,5000),});
</script>
</body>
</html>
I am using cesium 1.36 in IE11.
