Please assign Cesium.Ion.defaultAccessToken with an access token
How can we fix this message warning?
I generated my own token and then tried the below code in order to get rid of this message, but it doesn’t work. I also tried pieces of codes found in other posts with similar issue, but none of them worked. Does anybody know how to fix this?
Thanks a lot
// Cesium access token
Cesium.Ion.defaultAccessToken = 'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiI1ZDdmZWViMS0xZDVjLTRhYTUtYWI4Yy0yOGFkZmI4YjNmZGIiLCJpZCI6NTI3ODIsImlhdCI6MTYyMjU1NTY4M30.2Qry6HDCock7YrMi8GQaStykhvfbCfuJ-TDs7IRglmY'
// Bing map api key
Cesium.BingMapsApi.defaultKey = 'AlAmEdB42aWYJak6UYpV_TmC9ZJVjYkSVRU3DqpMxemy5smDVdGRoJ5ye7147B0E';
// Construct the viewer with just what we need for this base application
	timeline:false,
	animation:false,
	vrButton:true,
	sceneModePicker:false,
	infoBox:true,
	scene3DOnly:true,
	terrainProvider: Cesium.createWorldTerrain()
// Add credit to Bentley
viewer.scene.frameState.creditDisplay.addDefaultCredit(new Cesium.Credit('<a href="https://wingtra.com/" target="_blank"><img src="https://539308-1724691-raikfcquaxqncofqfm.stackpathdns.com/wp-content/uploads/wingtra-logo-small-1.png"/></a>'));
// Create tileset. Do not forget to reduce the default screen space error to 1
var tileset = new Cesium.Cesium3DTileset({
	url: '../Scene/Production_2.json',
	maximumScreenSpaceError : 1
// Override behavior of home button
viewer.homeButton.viewModel.command.beforeExecute.addEventListener(function(commandInfo) {
	// Fly to tileset
	viewer.flyTo(tileset);
	// Tell the home button not to do anything
	commandInfo.cancel = true;
// Add tileset to viewer and set initial camera position
viewer.zoomTo(tileset);
Hi @marketing-wingtra - welcome to the community forum! What fixes have you tried for this issue? Have you tried Omar’s suggestion in this thread?
Eli
