Problems with loading cesium terrain builder(i.e. ctb)generated terrain data
When I used the ctb terrain data in cesium, the spheres didn’t show up, and when I removed the terrain, the spheres showed up normally again. But this problem only appears in the new version of cesium, when I use the latest cesium it does not report any errors, when I use cesium 1.96 it shows the following error:
Cesium.js:85 An error occurred in “Py”: Failed to obtain terrain tile X: 0 Y: 0 Level: 0. Error message: “RangeError: Invalid typed array length: 8894653434”
Cesium.js:85 An error occurred in “Py”: Failed to obtain terrain tile X: 1 Y: 0 Level: 0. Error message: “RangeError: Invalid typed array length: 2017542741”
I looked for a lot of answers on the Internet, such as my terrain data missing layer.json file, such as not adding content-type:gzip response header, etc., I did, but it didn’t work.
Finally, when I used an older version of cesium 1.46, the terrain data was displayed. Why?
Is 1.46 the newest version where this still works?
Could you provide your code that shows how you load the terrain?
