I recently installed Cesium for Unreal Engine to make maps of the city of Paris and it’s an incredible tool!
However, I’d like to remove the Eiffel Tower from Cesium and replace it with a more detailed 3D Eiffel Tower model that I’ll import.
The problem is that after a lot of searching, I can’t find how to remove the Eiffel Tower, even with Cesium Cartographic Polygon.
Cesium Cartographic Polygon removes a piece of the map entirely with the ground and personally I’d like to keep the ground and remove the tower to put my 3D model there instead.
Can you help me? Thank you.
