Here’s my IonResource request line which details the Asset ID…
Cesium3DTileset url={IonResource.fromAssetId(1676057)} onReady={handleReady}
Here’s the 404 response that I get…
{“code”:“ResourceNotFound”,“message”:“Resource Not Found: /v1/assets/1676057/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJkYjk1OWEzOS0wM2UzLTQ1MmItYjVhNi0xOGE2NDAyNDc4ZjYiLCJpZCI6MjU5LCJpYXQiOjE2ODA1MzgxNTl9.ANfifMhFxb5agKqgDghPl1R__jvaz6dcEbkoNFM-txE”}
I don’t have this problem when I use the “Cesium OSM Building” asset whos ID is 96188. Replacing the asset ID in the above Ion asset request line with 96188 yields the following successful response…
{“type”:“3DTILES”,“url”:“https://assets.ion.cesium.com/asset_depot/96188/OpenStreetMap/2023-01-02/tileset.json?v=16",“accessToken”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIzNDZkMjdhMy1iY2U4LTQ5MjEtYWQ5ZC00MjFiZjZhMTdlNmIiLCJpZCI6MjU5LCJhc3NldHMiOnsiOTYxODgiOnsidHlwZSI6IjNEVElMRVMifX0sInNyYyI6ImRiOTU5YTM5LTAzZTMtNDUyYi1iNWE2LTE4YTY0MDI0NzhmNiIsImlhdCI6MTY4MjkwNDQ3MiwiZXhwIjoxNjgyOTA4MDcyfQ.NY49Wy6A-Rdm249If7nhG4sNbnMIfWljqlTfIQp1khs”,“attributions”:[{“html”:"<a href="https://cesium.com" target="_blank"><img alt="Cesium ion" src="https://assets.ion.cesium.com/ion-credit.png\“></a></span>”,“collapsible”:false},{“html”:”© <a href="https://www.openstreetmap.org/copyright\" target="_blank">OpenStreetMap contributors",“collapsible”:true}]}
How can I make my asset accessable from my React app?
More context:
I created the asset from a .glb file of a wind turbine.
Another question on the side, I am still using the default token. How do I replace the default token with the CesiumIon token that I have just created?
Thank you,
Tristan.
