Yes, it has data in it but cannot be viewed over in google earth, and it prompted some error about textures. I converted it with couple of online converters, gets empty drawings.
Are you downloading the satellite example or the model example? Or is it your own custom example? If it’s your own custom example, can you share the code for it?
Do you mean exporting from Google Earth so you can visualize it in CesiumJS? If so, you should be able to export KML/KMZ that you can render in CesiumJS.
No, I want to find a way to export georeferenced objects from cesium to .dwg without building expensive api from scratch. And I though kmz would help me half way
2019 m. rugpjūtis 8 d., ketvirtadienis 21:01:37 UTC+2, Omar Shehata rašė:
