When .kmz file converted to .gltf file, it renders differently (missing details) from what’s in Google Earth (see attached images). Could you please help to figure out what caused the problem? Thanks.
Here are the conversion steps:
(1)Change .kmz file to .zip file (.kmz file is attached)
(2)Drag and drop to http://cesiumjs.org/convertmodel.html to convert it to .gltf file
Thanks for providing the model. This is most likely a bug in the SketchUp COLLADA exporter or the COLLADA-to-glTF converter. Either way, I suspect we can fix it in the COLLADA-to-glTF converter. I submitted issue #342 for this. We’ll try to get a fix soon.
In the meantime, there is a simple workaround. In the glTF file, I removed 3042 from the states array in technique0 and technique1. I attached a screenshot and the modified glTF file.
This is a bug in the SketchUp COLLADA exporter (Google Earth must implement a workaround). We’ll add a workaround to the COLLADA-to-glTF converter. In the meantime, the easiest fix is to change the 0.0 in the “transparency” part of the .dae file to 1.0 before converting the file:
