I can not running Selection and Description section code in the Cesium tutorial in visualizing spatial data section.
Please help me. I need for help so necessary.
This is my code:
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>Hello World!</title>
<script src="../Build/Cesium/Cesium.js"></script>
<style>
@import url(../Build/Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
var wyoming = viewer.entities.add({
polygon : {
hierarchy : Cesium.Cartesian3.fromDegreesArray([
-109.080842,45.002073,
-105.91517,45.002073,
-104.058488,44.996596,
-104.053011,43.002989,
-104.053011,41.003906,
-105.728954,40.998429,
-107.919731,41.003906,
-109.04798,40.998429,
-111.047063,40.998429,
-111.047063,42.000709,
-111.047063,44.476286,
-111.05254,45.002073]),
material : Cesium.Color.RED.withAlpha(0.5),
outline : true,
outlineColor : Cesium.Color.BLACK
viewer.zoomTo(wyoming);
wyoming.description = '
<img
width="50%"
style="float:left; margin: 0 1em 1em 0;"
src="//cesiumjs.org/images/2015/02-02/Flag_of_Wyoming.svg"/>
<p>
Wyoming is a state in the mountain region of the Western
United States.
</p>
<p>
Wyoming is the 10th most extensive, but the least populous
and the second least densely populated of the 50 United
States. The western two thirds of the state is covered mostly
with the mountain ranges and rangelands in the foothills of
the eastern Rocky Mountains, while the eastern third of the
state is high elevation prairie known as the High Plains.
Cheyenne is the capital and the most populous city in Wyoming,
with a population estimate of 62,448 in 2013.
</p>
<p>
Source:
<a style="color: WHITE"
target="_blank"
href="http://en.wikipedia.org/wiki/Wyoming">Wikpedia</a>';
</script>
</body>
</html>
