Show DEM protruding out on the Globe
We are rendering a DEM in our react application and want our user to have an idea of inclination of the terrain, when they look at it laterally see this sandcastle for reference , now we want that our DEM should be protruding out on the globe just like it is happening here in Example 3 with geojson ,
For this we tried uploading DEM after transforming the altitude info using Raster Calculator in QGIS, but that file gets stuck in
Deploying new tileset for streaming… step at 4% , asset ID 2643275
update: now it’s showing this message
Something went wrong with this asset. To report this issue, please email support@cesium.com with the asset ID: 2643275.
Any help on this matter will be greately appreciated
Hi @zv-cesium,
Can you explain a bit more about the end result you are looking for?
If the root issue is the problem processing terrain in Cesium ion, I can move this thread to the proper category.
Thanks!
Gabby
Sure, so if you see here in the DEM
I am able to see the elevaion profile of the terrain , I am able to make out that it is a flat surface, similarly if the surface is tilted in a particular angle then i want my user to be able to see that.
For achieving this I thought if I add lets say 200 to the altitude of GEOTIF then it would appear like this , but when i do that , cesium cloud is unable to process that file.
Thanks @zv-cesium, I’ve moved this to the Cesium ion category so the relevant developers can help.
Hi @zv-cesium,
Looks like the asset with id 2643275 timed out with our 24 hour job limit. I have created an issue for the team to look at, they will try to re-run this job for you and get it tiled with an increased job limit.
Ankit
