Hi , I’m using cesium for creating 3d map, when I was loading the icons to the map it was floating. I thought it’s an issue in terrain. Even if enabled the terrain also icons floating. Is this a Bug?? Could anyone help me in this part.
Hiya,
We need to know more than that, otherwise the answer is No, lots of people use icons all the time, and it works for us. What are you doing? What does the code look like where to put the icons on the map? Etc. The best you can do is to make a Cesium Sandcastle that demonstrates the problem (just go to the default one, pop in code, and Share it to us).
Cheers,
Alex
