please help me
You managed to load an offline map? I thought you can’t work offline
是的,我可以加载离线地图,但是加载出来的效果并不好。
Yes, I can load offline maps, but it doesn’t work very well.
Can you please link to the how to do it?
Direct use of CesiumTileMapServiceRasterOverlay loading has been downloaded offline maps.
please help me .
The effect looks pretty bad from a distance or up close !!!!!!!!! Hope the officials can help me!
This is my in the unreal engine by Cesium components CesiumTileMapServiceRasterOverlay load out local offline maps, but the effect is very bad!
Hi @BB_Y,
Thanks for including an image of your issue. In the future, please refrain from spam on the forum. Our team will be able to better assist you if you keep discussion to a single thread, where we will aim to respond within 48 hours.
We have been able to successfully load TMS Overlays with Cesium for Unreal, so I’m not sure what could be going wrong. Is this your personal data? If so, have you tried to load your TMS outside of Cesium? It could be that the data is malformed.
If you are able to share, it would also help to include a screenshot of the parameters you are using on the CesiumTileMapServiceRasterOverlay component. Thank you.
