hi
I have a 3dtileset(raster, dem) which covers a large area, is there a way that I give a bounding area and Cesium will only show the 3dtiles inside that area?
hi
You can use Cartographic Polygons:
I read an article about Cartographic Polygons. But I need the outside of the polygon not to be rendered, is that possible with Cartographic Polygons?
Yes. Just toggle the Invert Selection property on the CesiumPolygonRasterOverlay.
Hello. Desiring to create a bounding area like the original post I have followed the steps in the âClipping Tilesetsâ tutorial (Twice) and selected the âInvert Selectionâ box and also refreshed the tileset and nothing is being clipped. Where might I look to ascertain my problem? Thanks!
I added a CesiumPolygonRasterOverlay to the Cesium3DTileset actor and then added a polygon array, so it was cut and displayed normally.
Thank you. That was the issue. When I added the CesiumPolygonRasterOverlay I did not have the Tileset actor selected. It all works now.
