So I have some polylineVolumes that render in full when the camera is sufficiently far away from the entity. When the camera encroaches on the physical entity, there is unpredictable rendering behavior where the entity can become clipped at a seemingly random distance from the camera. This happens to some entites but not all. I’m not sure what is going on. See the gif below…
Nothing crazy here…
<Entity
polylineVolume={{
positions: track_pos,
shape: computeCircle(2.0),
material: Color.WHITE.withAlpha(0.05),
availability={availability} />
I don’t want the clipping of the volume’s rendering to be tied to the camera whatsoever. I’d like the camera to fly through objects if they do intersect. As it is, it appears the object is being clipped at some unknown z-distance in front of the camera, for some but not all entities.
Cesium 1.58 with React (Resium), Chrome 71.
demo_issue.mov (1.66 MB)
