Hello, I’ve been running into an issue with cesium that is stopping me from building my unreal project. I have been able to work on the project prior to a few days ago when I started getting building errors. I’m using Unreal version 5.5.4 and Cesium version 2.15 and working/building on Mac. I have also uninstalled and reinstalled Cesium to see if that would fix my issues as they have only recently developed. I have also regenerated project files but still the same deal.
The initial error that I was experiencing when building the project was this:
Exception while generating include data for SkyPlexC2: Unable to instantiate module ‘UnrealEd’: Unable to instantiate UnrealEd module for non-editor targets.
(referenced via Target → SkyPlexC2.Build.cs → CesiumEditor.Build.cs)
I was able to fix this adding:
if(Target.bBuildEditor){
PrivateDependencyModuleNames.AddRange( new string {
“UnrealEd”,
“EditorStyle”,
“EditorSubsystem”,
“LevelEditor”
However, after adding this another error appears that says:
Missing precompiled manifest for ‘CesiumEditor’, '/Users/Shared/Epic Games/UE_5.5/Engine/Plugins/Marketplace/Cesiumfo27e669801be6V8/Intermediate/Build/Mac/UnrealGame/Development/CesiumEditor/CesiumEditor.precompiled. This module can not be referenced in a monolithic precompiled build, remove this reference or migrate to a fully compiled source build.
This module was most likely not flagged during a release for being included in a precompiled build - set ‘PrecompileForTargets = PrecompileTargetsType.Any;’ in CesiumEditor.Build.cs to override.
If I do add the PrecompileForTargets = PrecompileTargetsType.Any; nothing changes and I still have the same error. It also suggests checking if its “Type” is correct which I have done and confirmed it as being “Editor”.
Thank you for taking the time to read this.
