So I think if your Google Earth Enterprise server is set up correctly, you should be able to point to it in CesiumJS. Here’s a more recent example that you can test with:
That might be a good place to start. That’s all on the Cesium side. If you need help with the GEE software itself you might get more help by asking them on their GitHub page: https://github.com/google/earthenterprise/issues
My conclusion is the version problem, the cesium example server is 5.1, my compiled googleEarthenterpise is 5.2, and the EC connection http://www.earthenterprise.org/3d is also not acceptable; cesium’s support for google earth is not updated, then I want to develop andriod google earth client is no plan, then google earth enterprise open source does not have much significance, because there is no development client, can not be used for secondary development? What experience do you have to introduce? Thank you very much for your reply.
