Which viewer and Any example for Point Cloud PNTS
A PNTS file is created from Point Cloud Data. Any examples to show how it published to Cesium
No.
Would like to publish PNTS data to Cesium. Any example or code can be shared?
Browser: Chrome; Cesium 1.28
Here’s a few links to check out:
Spec for the pnts format: https://github.com/AnalyticalGraphicsInc/3d-tiles/tree/master/TileFormats/PointCloud
Cesium demos (local):
http://localhost:8080/Apps/Sandcastle/index.html?src=3D%20Tiles%20Point%20Cloud%20Styling.html&label=3D%20Tiles
http://localhost:8080/Apps/Sandcastle/index.html?src=3D%20Tiles%20Point%20Cloud.html&label=3D%20Tiles
Sample code for generating pnts tiles:
https://github.com/AnalyticalGraphicsInc/3d-tiles-tools/blob/master/samples-generator/lib/createPointCloudTile.js
Also make sure you are running on a newer version of Cesium. Version 1.28 does not have 3D Tiles support.
Let me know if you have other questions.
