3D Tiling Pipeline converter
Hi All,
I want to know and get advice. I do converting 3D data CityGML in .gml format included appearance folder. The result show only the building without the appearance(texture image.png).
How can i do to solve the problem?
above my folder data
after conversion
the actual data it should be
conversion command line
Could somebody help me on this…
Thanks
Thanks for your question. This is a known issue that will be fixed in the next release of the 3D Tiling Pipeline. For the moment, please try the workaround below.
Prior to running the 3d-buildings-tiler command, set the following environment variable:
SET MAGICK_CODER_MODULE_PATH=<full-path-to-binary-directory>
For example, here is how that command looks on my machine:
SET MAGICK_CODER_MODULE_PATH=C:\Cesium\tilers\bin
In future versions of the 3D Tiling Pipeline, this variable won’t need to be explicitly set.
Let us know if you encounter further issues.
Matt
Many thank Matt… It work for me now…
to extend this question. i also do for converting LOD 4 in CityGML.
Did anybody found the error similar like this?
We’ve seen this one time before, and it appears to be a problem with how the CityGML data was generated/exported. We don’t have much information available on what causes it, but if you send us a sample of your data and any information on how it was generated, we would be glad to take a look.
For the time being, there is a workaround that may solve it for you. Does the gml file have tags that look like this?
      <bldg:roominstallation xlink:href="some-alphanumeric-sequence"/>
If so, please try removing them and tiling the data afterward.
Matt
Hi Matt,
I already remove the tag… but its will show this error.
How I can shared data to you? can we use telegram?
