For the cesium version 2.2.0,UE5.2 ,When I use Cesium ion Raster Overly, I place my camera at a certain angle, the remote sensing image suddenly turns into a white block. When rotating at that point by some angle, the white block is normal.It seems that the previous version 1.28.0 did not encounter this issue. Are there any parameters that need to be configured in version 2.2.0?
That’s very strange, I’m not sure why that’s happening! Where in the world do you see this issue happening? Or does it happen everywhere?
Thank you very much for your help and answer.
Almost anywhere, I have found this problem at several points on Earth, which can be tested at longitude and latitude, 30.8134 north latitude, 110.9985 east longitude.
Phenomenon: At the beginning of loading the image of this location, no symptoms appeared. But after a few seconds, when the image data is loaded and zoomed in to a high level and the camera is rotated to a certain angle, it will appear. But after upgrading cesiumForUnreal from 2.2.0 to 2.4.1, this issue did not occur again.
