hi
I built the scene and ran the exe file
- I can’t move to the keyboard
- The color is all gone like in the picture
Did I set it up wrong?
I followed this tutorial.
hi
Hmmm not sure what would cause that. Are you able to build and run the Cesium for Unity Samples project? Release v1.2.1 · CesiumGS/cesium-unity-samples · GitHub
Thank you. I solved it. And I have one more question. Is there a manual for multiplayer environment using cesium for Unity?
It would be good to share your solution, in case others run into the same problem.
There’s no multiplayer manual for Cesium for Unity. In fact I don’t think we’ve ever tried it. But if you try it and run into specific problems, we may be able to help.
