I am working on a project in the Industrial Engineering department of my University and for an upcoming IE conference in May we would like to showcase a drone simulation project we have been working on. The concern is that due to limited bandwidth we will not have optimal performance to show the simulator.
Will allow us to host and serve the tiles. My confusion is how we generate the actual tile data. e.g. 20x20 square distance from lat/lon coords using x zoom levels.
From the Cesium Terrain Builder information it would seem I need to create GDAL raster representing a Digital Elevation Model (DEM).
How do I create an input raster?
Lastly, is there a better way to use cached tile data for offline use?
However, if you have your own terrain data you can use tools like the Cesium Terrain Builder to create a local tileset (note that this software was not created or maintained by the Cesium team so I’m not very familiar with the specifics on how it works)
AGI (The company that employs most of the Cesium team) has a commercial product called the STK Terrain Server that can process raw terrain data into the quantized mesh terrain format used by the CesiumTerrainProvider for local use. If you would like to know more about this product please send an email to todd@agi.com
If your team / school has the means, would highly recommend a purchase of STK Terrain Server, it’s well worth the $$, and will save you a lot of time / headaches.
As a purely technical suggestion, you might want to try gdaltranslate and gdaldem to translate vector DEMs to raster.
