All,
Been starting to play around with Cartographic Polygons, one thing that would help me well, would be the ability to Export a Shapefile from Civil3D / Qgis etc as a boundary to then use as the Cartographic Boundary, possible ? I’m not a progammer of any means so keep it real
A SHP file is a geospatial vector data file format.
Cesium ion does not currently support tiling SHP files. If this is something you would like us to support, please let us know more information about your use case.
Ankit
Sure thing, I think there is a massive need for SHP ( or anything else similar to SHP ) given that Cesium main workflow is geolocation, makes sense to tie in with Civil / QGIS packages out there.
