I am uploading a 3D model asset to Cesium Ion using the REST API, but I am facing two issues after the asset is processed and rendered in the viewer.
Asset Details
Asset ID: 4505860
Upload Method: REST API
Formats Tested:
.obj,.glb
Issues
After rendering the asset, the model appears floating in the air instead of aligning with the ground/terrain.
The asset is not rendering at the correct geographic location where it should appear.
I expected the model to render at its actual location on the terrain, but instead it appears offset and elevated.
