I want to build a compass for use in a sequenced animation, but I can’t figure out how to find the GeoReference actor. Everything I’ve read says its in the actor, but where is the actor?
Can you share the instructions you’re following? Unreal Engine has a built-in GeoReferencing plugin, and I believe it has a GeoReference Actor, but this is not necessarily used with Cesium for Unreal. If that’s what you’re looking for, you’ll need to enable that plugin. Cesium for Unreal also has an Actor called a CesiumGeoreference, which has a similar purpose.
