Original Post from @h.tkcreate in Japanese Forum : Link
I am in the process of checking to see if it is possible to use cesium ions in a self-study.
I have not been able to solve the problem, so I came to this forum.
I have created a CIM model, converted it to GDL format, imported it into Cesium, and it is displayed, but the coordinates are misaligned. I would like to know if there is a solution to this problem.
The problem is that the conversion to WGS84 is not working.
I have used Qgis and other tools, but I have given up because of the difficulty in exporting the 3D model.
If there are any conversion routes from dwg to GDL that we can try, please let us know. Info.
Information on lectures, videos, etc. that may help us solve the problem.
I would appreciate it if you could give me some hints on how to solve this problem.
Hi @Mizuki0522,
Can you please ask the user if they are able to provide us with the asset id for the above and which options they picked while uploading their data to Cesium ion.
Through our API, the user can specify their CRS and position for some assets depending on the source data type which may be helpful for the user’s case.
Ankit
@Ankit_Trehan, @h.tkcreate choose 3DModel(tile as 3D Tiles). They will share the asset ID in DM. Cimデータの位置ずれを補正したいのですが、、 - #5 by h.tkcreate
@Mizuki0522 @Ankit_Trehan
DMにてアセットID送信しました。ご確認ください。。
That asset was uploaded as a GLB file with the 3D Model setting. For positioning these types of assets we recommend creating the GLB file with the data in a local coordinate system centered around the origin. Then use the Adjust Tileset Location button in the right detail panel to set the position after it is tiled. See the 3D Model Tiling Guide for more information.
Please let us know if that helps.
GLB ファイルの配置とタイル化のプロセスを詳しく説明していただきありがとうございます。
原点を中心とするローカル座標系とタイルセット位置の調整機能を使用するという推奨事項を確認し、それに基づいて作業を行ってみます。
ありがとうございました!
