Tried to convert dae model to 3D tiles, and it’s working, except the textures are missing in resulting 3D tiles model.
Any hint how to add dae file and accompanied textures folder to Cesium Ion “My Assets” ?
Maybe textures should be placed in some spec folder or something ??
*Also tried KML format, *
and its working and even textures are present, but cannot alter locations data which is a must for me.
Maybe there is a way to alter KML locations data in “My Assets”?
Attached testing dae model and accompanied texture folder, and examples of the same dae model converted as glft and 3D tiles format.
Converting SketchUp skp models to 3D tiles, to be added to the Cesium web map with custom terrain.
dae format is the most convenient since I need to manually adjust lat/lon/elev for each model.
Previously working with glft files but 3D tiles are much better option.
Cesium 1.52, Win 10 Pro 64bit, Edge 11/FF/Chrome/Android
3D_modeli.zip (3.64 MB)
