Upon loading a 3d tile with mulitiple dae files received the below error.
Something went wrong with this asset. To report this issue, please email support@cesium.com with the asset ID: 2765487.
To help resolve this faster, include any relevant information about your data, such as what software you used to export it.
Looking at the logs, it seems like the job associated with the asset id has passed. Can you please share with me a screenshot of what you are seeing on the screen? This might be a bug with what is shown on the client and backend
Ankit
It looks like the asset has a tileset.json that is pointing directly to a dae file which is causing errors when rendering. A 3d tile tileset doesn’t contain dae files so the model is unable to be read by Cesium ion when loading it. I would advise you to check the model and pull the dae file out and upload that to be run through the model tiling pipeline.
Ankit
Yes my zip contains multiple .dae files and tileset points to those .dae files. Will i need to convert the dae files to some other format?
Yes if you want to upload the dae files as a 3d Tiles dataset, you would have to ensure that the dataset is compliant with the 3D Tiles spec: 3D Tiles Specification
Alternatively, the recommended approach would be that you can upload your dae files directly and let ion tile them to 3D Tiles as a 3D Model upload.
Ankit
