I am an active Doarama user, and I really appreciate the graphics.
Doarama uses Cesium for the terrain graphics, but there is a cloud layer that is glued on the ground. This cloud layer serves no purpose, and is very annoying.
Doarama developers say they have no control of the cloud layer, so I am posting this to get a first clue regarding how to fix this problem.
The cloud layer only shows up in low altitudes. When the view point is at higher altitudes the cloud layer disappears.
If you take a look at this Doarama flight rendering, you will immediately see cumulus clouds glued to the terrain, including shadows from the clouds:
https://doarama.com/view/1387761
I use Doarama to memorize terrain details important for low-level ridge flying. The "clouds" hide important information such as power lines.
I am using Doarama in Google Chrome.
Many thanks in advance for your help!
Best regards
Karl Osen
www.karlosen.com
