this is example structure picture .
and i attached json file and please check json file
tileset.json
Tile_+000_+021.json
so i tried to combine this dataset.
but… 3d-tiles-tools show me this error.
:~/light$ npx 3d-tiles-tools combine -i ./ -o ./combine_test
Need to install the following packages:
3d-tiles-tools@0.4.2
Ok to proceed? (y) y
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
[11:47:51.808] ERROR (CLI): No data found for Tile_+001_+021/Tile_+001_+021/Tile_+001_+021_L20_0uuuu20.b3dm
err: {
“type”: “TilesetError”,
“message”: “No data found for Tile_+001_+021/Tile_+001_+021/Tile_+001_+021_L20_0uuuu20.b3dm”,
“stack”:
Error: No data found for Tile_+001_+021/Tile_+001_+021/Tile_+001_+021_L20_0uuuu20.b3dm
at TilesetCombiner.combineContentInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:168:19)
at TilesetCombiner.combineTileInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:132:24)
at /home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:116:24
at Tiles.traverseExplicitInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tilesets/tilesets/Tiles.js:111:37)
at Tiles.traverseExplicitInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tilesets/tilesets/Tiles.js:114:29)
at async Tiles.traverseExplicitInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tilesets/tilesets/Tiles.js:114:17)
at async Tiles.traverseExplicit (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tilesets/tilesets/Tiles.js:100:9)
at async TilesetCombiner.combineTilesetsInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:114:9)
at async TilesetCombiner.combineContentInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:191:13)
at async TilesetCombiner.combineTileInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:132:13)
at async /home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:116:13
at async Tiles.traverseExplicitInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tilesets/tilesets/Tiles.js:111:31)
at async Tiles.traverseExplicitInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-toolanjion@LAPTOP-FEEB6E09:~/light$
at async TilesetCombiner.combineInternal (/home/anjion/.npm/_npx/e97e2e75cde22e22/node_modules/3d-tiles-tools/build/src/tools/tilesetProcessing/TilesetCombiner.js:85:9)
i was never repeated the path.
but combine command is repeated the path.
even other laptop too
i think something is wrong
someone have simillar experience? or someone have solution about this error?
