Large CorridorGeometry graphic was cut off when moving the globe.
created large graphic using CorridorGeometry graphic, start moving the globe => notice the graphic was cut off. This behavior is different with other geometry such as circle, ...
Depending on where the start point is, this clipping behavior can be seen at creation of the graphic too.
my sandcattle source code here:
All graphics, circle, polygon, oval (using CorridorGeometry), ... should behave consistently when moving the globe - need to support this. Currently, CorridorGeometry has clipping effect as described above.
Windows 10, Linux 6, Linux 7. Chrome, Firefox, ...
https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/#c=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
Thanks for reporting this issue and for providing a Sandcastle example. I’ve opened a bug report for it here:
https://github.com/AnalyticalGraphicsInc/cesium/issues/7627
