Cesium version: 1.131
I try to create a material for a vertical wall, but i am struggling with the correct way to define it, since whatever i try, i am just getting stripes on it. Worth to mention is, i am using a vertical polygon, so a Cesium primitive to assign the material.
The polygon is coming from GeoJSON like this:
type: 'Feature',
geometry: {
type: 'Polygon',
coordinates: [
[4.725512471801164, 50.88101331210589, 34.04014368685602],
[4.725513347194739, 50.8810129046137, 42.76989201868262],
[4.725652873658409, 50.880958198909866, 42.71970368259534],
[4.725654056530405, 50.88095773512771, 33.74971261545709],
properties: {
materialType: 'greenwall',
What i have so far is:
primitive.appearance.material = new Material({
translucent: false,
fabric: {
type: 'GreenWall',
uniforms: {
leafColorDark: new Color(0.1, 0.35, 0.1, 1.0),
leafColorLight: new Color(0.4, 0.8, 0.3, 1.0),
redPlantDark: new Color(0.5, 0.15, 0.08, 1.0),
redPlantLight: new Color(0.8, 0.3, 0.15, 1.0),
scale: new Cartesian2(8.0, 3.0),
source: `
// Simple noise function
float hash(vec2 p) {
return fract(sin(dot(p, vec2(127.1, 311.7))) * 43758.5453);
float noise(vec2 p) {
vec2 i = floor(p);
vec2 f = fract(p);
f = f * f * (3.0 - 2.0 * f);
float a = hash(i);
float b = hash(i + vec2(1.0, 0.0));
float c = hash(i + vec2(0.0, 1.0));
float d = hash(i + vec2(1.0, 1.0));
return mix(mix(a, b, f.x), mix(c, d, f.x), f.y);
czm_material czm_getMaterial(czm_materialInput materialInput) {
czm_material material = czm_getDefaultMaterial(materialInput);
vec2 st = materialInput.st;
// Texture coordinates for detail
vec2 texSt = vec2(st.x * scale.x, st.y * scale.y);
// High frequency noise for plant detail
float n1 = noise(texSt * 3.0);
float n2 = noise(texSt * 7.0);
float n3 = noise(texSt * 15.0);
// Combine noise layers for both detail and plant type variation
float detail = n1 * 0.5 + n2 * 0.3 + n3 * 0.2;
float plantType = detail; // Use same noise for plant type
// Define colors
vec3 green1 = leafColorDark.rgb;
vec3 green2 = leafColorLight.rgb;
vec3 red1 = redPlantDark.rgb;
vec3 red2 = redPlantLight.rgb;
vec3 mix1 = vec3(0.15, 0.4, 0.12);
vec3 mix2 = vec3(0.65, 0.8, 0.45);
// Selectors based on noise (creates organic patches)
float isRed = smoothstep(0.3, 0.5, plantType);
float isMix = smoothstep(0.65, 0.8, plantType);
// Choose color pair
vec3 c1 = mix(green1, red1, isRed);
c1 = mix(c1, mix1, isMix);
vec3 c2 = mix(green2, red2, isRed);
c2 = mix(c2, mix2, isMix);
// Mix colors based on noise
vec3 plantColor = mix(c1, c2, smoothstep(0.2, 0.8, plantType));
// Add shadow variation
float shadow = noise(texSt * 5.0 + 10.0);
plantColor *= 0.75 + 0.25 * shadow;
// Lighting
vec3 normal = normalize(materialInput.normalEC);
vec3 lightDir = normalize(czm_sunDirectionEC);
float diffuse = max(dot(normal, lightDir), 0.3);
material.diffuse = plantColor * diffuse;
material.specular = 0.05;
material.shininess = 3.0;
material.alpha = 1.0;
return material;
But i always receive something like that here:
Applying the same material to a horizontal polygon, lying on the ground for instance works. So i assume it has something to do with the z-coordinates and not handling them correctly.
Has someone an idea on how to tackle that?
BR Thomas
