Hi it is me again.
I am trying to package my ue4.26 project with 1.7.0 for Windows64 Shipping
I get the following
UATHelper: Packaging (Windows (64-bit)): ERROR: Unable to instantiate module ‘UnrealEd’: Unable to instantiate UnrealEd module for non-editor targets.
UATHelper: Packaging (Windows (64-bit)): (referenced via Target → CesiumRuntime.Build.cs → WorldBrowser.Build.cs)
Below is my CesiumRuntime.Build.cs
// Copyright 2020-2021 CesiumGS, Inc. and Contributors
using UnrealBuildTool;
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Reflection;
public class CesiumRuntime : ModuleRules
public CesiumRuntime(ReadOnlyTargetRules Target) : base(Target)
PCHUsage = ModuleRules.PCHUsageMode.UseExplicitOrSharedPCHs;
PublicIncludePaths.AddRange(
new string[] {
Path.Combine(ModuleDirectory, "../ThirdParty/include")
PrivateIncludePaths.AddRange(
new string[] {
// ... add other private include paths required here ...
string libPrefix;
string libPostfix;
string platform;
if (Target.Platform == UnrealTargetPlatform.Win64)
platform = "Windows-x64";
libPostfix = ".lib";
libPrefix = "";
else if (Target.Platform == UnrealTargetPlatform.Mac)
platform = "Darwin-x64";
libPostfix = ".a";
libPrefix = "lib";
else if (Target.Platform == UnrealTargetPlatform.Android)
platform = "Android-xaarch64";
libPostfix = ".a";
libPrefix = "lib";
else if (Target.Platform == UnrealTargetPlatform.Linux)
platform = "Linux-x64";
libPostfix = ".a";
libPrefix = "lib";
else
platform = "Unknown";
libPostfix = ".Unknown";
libPrefix = "Unknown";
string libPath = Path.Combine(ModuleDirectory, "../ThirdParty/lib/" + platform);
string releasePostfix = "";
string debugPostfix = "d";
bool preferDebug = (Target.Configuration == UnrealTargetConfiguration.Debug || Target.Configuration == UnrealTargetConfiguration.DebugGame);
string postfix = preferDebug ? debugPostfix : releasePostfix;
string[] libs = new string[]
"async++",
"Cesium3DTilesSelection",
"CesiumAsync",
"CesiumGeometry",
"CesiumGeospatial",
"CesiumGltfReader",
"CesiumGltf",
"CesiumJsonReader",
"CesiumUtility",
"draco",
//"MikkTSpace",
"modp_b64",
"spdlog",
"sqlite3",
"tinyxml2",
"uriparser"
// Use our own copy of MikkTSpace on Android.
libs = libs.Concat(new string[] { "MikkTSpace" }).ToArray();
PrivateIncludePaths.Add(Path.Combine(ModuleDirectory, "../ThirdParty/include/mikktspace"));
if (preferDebug)
// We prefer Debug, but might still use Release if that's all that's available.
foreach (string lib in libs)
string debugPath = Path.Combine(libPath, libPrefix + lib + debugPostfix + libPostfix);
if (!File.Exists(debugPath))
Console.WriteLine("Using release build of cesium-native because a debug build is not available.");
preferDebug = false;
postfix = releasePostfix;
break;
PublicAdditionalLibraries.AddRange(libs.Select(lib => Path.Combine(libPath, libPrefix + lib + postfix + libPostfix)));
PublicDependencyModuleNames.AddRange(
new string[]
"Core",
// ... add other public dependencies that you statically link with here ...
PrivateDependencyModuleNames.AddRange(
new string[]
"RHI",
"CoreUObject",
"Engine",
"MeshDescription",
"StaticMeshDescription",
"HTTP",
"LevelSequence",
"Projects",
"RenderCore",
"SunPosition", "WorldBrowser"
// Use UE's MikkTSpace on non-Android
if (Target.Platform != UnrealTargetPlatform.Android)
PrivateDependencyModuleNames.Add("MikkTSpace");
PublicDefinitions.AddRange(
new string[]
"SPDLOG_COMPILED_LIB",
"LIBASYNC_STATIC",
// "CESIUM_TRACING_ENABLED"
if (Target.bCompilePhysX && !Target.bUseChaos)
PrivateDependencyModuleNames.Add("PhysXCooking");
PrivateDependencyModuleNames.Add("PhysicsCore");
else
PrivateDependencyModuleNames.Add("Chaos");
if (Target.bBuildEditor == true)
new string[] {
"UnrealEd",
"Slate",
"SlateCore",
"WorldBrowser"
DynamicallyLoadedModuleNames.AddRange(
new string[]
// ... add any modules that your module loads dynamically here ...
PCHUsage = PCHUsageMode.UseExplicitOrSharedPCHs;
PrivatePCHHeaderFile = "Private/PCH.h";
CppStandard = CppStandardVersion.Cpp17;
bEnableExceptions = true;
if (Target.Platform == UnrealTargetPlatform.Android &&
Target.Version.MajorVersion == 4 &&
Target.Version.MinorVersion == 26 &&
Target.Version.PatchVersion < 2)
// In UE versions prior to 4.26.2, the Unreal Build Tool on Android
// (AndroidToolChain.cs) ignores the CppStandard property and just
// always uses C++14. Our plugin can't be compiled with C++14.
// So this hack uses reflection to add an additional argument to
// the compiler command-line to force C++17 mode. Clang ignores all
// but the last `-std=` argument, so the `-std=c++14` added by the
// UBT is ignored.
Type type = Target.GetType();
FieldInfo innerField = type.GetField("Inner", BindingFlags.Instance | BindingFlags.NonPublic);
TargetRules inner = (TargetRules)innerField.GetValue(Target);
inner.AdditionalCompilerArguments += " -std=c++17";
and here my CesiumEditor.Build.cs
using System;
using System.IO;
using System.Linq;
public class CesiumEditor : ModuleRules
public CesiumEditor(ReadOnlyTargetRules Target) : base(Target)
new string[] {
// ... add public include paths required here ...
new string[] {
string libPrefix;
string libPostfix;
string platform;
if (Target.Platform == UnrealTargetPlatform.Win64) {
libPrefix = "";
else if (Target.Platform == UnrealTargetPlatform.Mac) {
libPostfix = ".a";
libPrefix = "lib";
else if(Target.Platform == UnrealTargetPlatform.Android) {
libPostfix = ".a";
libPrefix = "lib";
else if(Target.Platform == UnrealTargetPlatform.Linux) {
libPostfix = ".a";
libPrefix = "lib";
else {
"CesiumIonClient",
"csprng"
if (preferDebug)
break;
new string[]
"Core",
"UnrealEd",
"CesiumRuntime"
new string[]
"CoreUObject",
"Engine",
"ApplicationCore",
"Slate",
"SlateCore",
"MeshDescription",
"HTTP",
"MikkTSpace",
"Chaos",
"Projects",
"InputCore",
"PropertyEditor",
"DeveloperSettings"
// ... add private dependencies that you statically link with here ...
new string[]
new string[]
// UBT is ignored.
The solution will be probably to move WorldBrowser from Runtime to Editor build. I have done this but the project can not be compiled because CesiumGeoreference.cpp wants the WorldBrowser
Do you know how do I move “WorldBrowser” module from Runtime to Editor build cs without having the missing error ?
