Thanks for reporting this. It looks like the UE 5.2 and 5.3 version of the plugin available from the Unreal Marketplace has a bug where it is missing the Config.ini file that fixes this and other problems. I described the issue in more detail here:
This seems to be a problem introduced by Epic in the course of publishing our plugin. We’ll try to get them to fix it as soon as possible, but in the meantime the workaround is to use our build of the plugin instead of Epic’s. You can find instructions for installing our build here:
