REST API options when creating a new asset
I would like to define the location of a OBJ mesh model during the upload to Cesium ION using the REST API. Shall I pass the position while calling the POST method ? Ion REST API documentation – Cesium
Actually, where can I find the documentation on the options that can be used?
Hi @julesmorel ,
Please see the API docs for creating a new asset Ion REST API documentation – Cesium
Expand the options section and select which type of OBJ you are uploading from the dropdown menu (3D_CAPTURE, 3D_MODEL, BIM_CAD). Then you will see under options there is a position property.
Luke
Thank you for you prompt reply @Luke_McKinstry
I missed the dropdown menu
Regards
