I clone the git repository and I'm facing a 404 error after building the project (build, buildApps, release)
http://localhost:8080/ThirdParty/dojo-release-1.10.4/dijit/form/TextArea.js Failed to load resource: the server responded with a status of 404 (Not Found)
This prevent Sandcastle to work properly.
The file is missing indeed in the directory.
I don't know if the problem comes from me or not and what I should do to resolve it.
Regards
Olivier
hannah
April 13, 2016, 2:20pm
2
Hello Olivier,
If you look in our GitHub repository, that file is at that location. Try re-cloning the repository to make sure you pulled down all of the files.
Hannah
hannah
April 13, 2016, 4:07pm
3
Actually, it looks like we’re experiencing the bug you found with our continuous integration build. See this issue: https://github.com/AnalyticalGraphicsInc/cesium/issues/3838
We should get it fixed soon. Thanks!
-Hannah
It’s a typo error.
SandCastle is looking for TextArea.js when the file is named Textarea.js.
Not sure which one is wrong between the code or the file name…
hannah
April 13, 2016, 6:33pm
5
Thanks! It looks like that got changed accidentally recently. I didn’t notice it before because windows has a case insensitive file system.
It submitted a fix here, and it should be merged in shortly: https://github.com/AnalyticalGraphicsInc/cesium/pull/3841
Thanks again,
Hannah
