Standard guidelines for exposing Metadata API
To bring Godot’s Cesium TileMetadata.h closer to the granular, modular system Unity uses, need to break out responsibilities into specialized classes rather than funneling everything through TileMetadata + CesiumPropertyInfo. Here’s a structured list of changes and additions:
:key: Proposed Class Additions for Granularity
1. Feature ID Sources
  • FeatureIdAttributeSource
    • Handles feature IDs embedded in vertex attributes.
    • Provides GPU‑friendly pathways for instancing/selection.
  • FeatureIdTextureSource
    • Manages feature IDs stored in textures.
    • Supports caching and late binding for texture‑based IDs.
  • FeatureIdImplicitSource
    • Provides implicit ID generation when no explicit source exists.
    • Useful for fallback or procedural tiles.
2. Property Wrappers
  • PropertyTableProperty
    • Represents a single property with type‑safe getters.
    • Lazy conversion (only convert when accessed).
    • Mirrors Unity’s CesiumPropertyTablePropertyImpl.
3. Value Layer
  • MetadataValue
    • Encapsulates typed accessors (as_float64(), as_vec3f(), try_get_enum()).
    • Small‑object optimization to reduce Variant churn.
    • Dedicated conversion layer separate from template helpers.
4. Metadata Coordination
  • MetadataCoordinator
    • Centralized manager for multiple property tables.
    • Provides unified API for querying properties across tables.
    • Similar to Unity’s CesiumMetadataImpl.
5. Utility Functions
  • MetadataUtility
    • Static helpers for parsing, validation, and conversion.
    • Enum range validation, matrix mapping, color type handling.
    • Equivalent to Unity’s CesiumFeaturesMetadataUtility.
6. Matrix & Enum Support
  • MatrixPropertyHandler
    • Implements conversion paths for Mat2/Mat3/Mat4.
    • Maps glm matrices to Godot Matrix types.
  • EnumPropertyHandler
    • Stores enum tables and validates ranges.
    • Prevents silent coercion into scalars/booleans.
:hammer_and_wrench: Structural Changes to TileMetadata.h
  • Refactor TileMetadata into a facade:
    • Delegates to specialized classes (FeatureIdSource, PropertyTableProperty, MetadataValue).
    • Keeps Dictionary/Variant outputs for GDScript ergonomics.
  • Introduce caching layer:
    • Preconvert common types (e.g., Float64→Float32 vec arrays).
    • Avoid repeated coercions in hot loops.
  • Add accessor API:
    • get_property(name) → returns PropertyTableProperty.
    • get_feature_id(source, index) → dispatches to correct FeatureIdSource.
:bar_chart: Comparison Snapshot
Unity Granular System Godot Current Proposed Godot Additions
CesiumFeatureIdAttributeImpl None FeatureIdAttributeSource
CesiumFeatureIdTextureImpl None FeatureIdTextureSource
CesiumPropertyTablePropertyImpl CesiumPropertyInfo PropertyTableProperty
CesiumMetadataImpl TileMetadata MetadataCoordinator
CesiumMetadataValueImpl Template helpers MetadataValue
CesiumFeaturesMetadataUtility Inline templates MetadataUtility
:bullseye: Outcome
By modularizing into these classes:
  • Granularity: Each metadata source/type is handled independently.
  • Performance: Typed accessors and caching reduce Variant overhead.
  • Extensibility: New metadata forms (colors, packed bitfields, GPU pathways) can be added without touching core.
  • Developer ergonomics: Typed wrappers for C++ performance, Dictionary/Variant for GDScript prototyping.
