Strange behaviour of 3DTiles when using CityGML
I am trying to visualize a CityGML file into Cesium. I am able to do so both into sandcastle and into a story displaying the corresponding asset. However, when I try to use the Cesium viewer embedded into a html file, nothing is shown. This, however, occurs only for certain assets’ ids, while others are correctly displayed.
Here is my html code:
<!DOCTYPE html>
<html lang="it">
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
    <title>Esempio base Cesium</title>
    <style>
        html, body, #cesiumContainer {
            width: 100%;
            height: 100%;
            margin: 0;
            padding: 0;
            overflow: hidden;
    </style>
</head>
<body>
    <div id="cesiumContainer"></div>
    <script>
        function loadCesium(callback) {
            var script = document.createElement('script');
            script.src = 'https://cesium.com/downloads/cesiumjs/releases/1.95/Build/Cesium/Cesium.js';
            script.onload = function() {
                var link = document.createElement('link');
                link.rel = 'stylesheet';
                link.href = 'https://cesium.com/downloads/cesiumjs/releases/1.95/Build/Cesium/Widgets/widgets.css';
                document.head.appendChild(link);
                callback();
            document.body.appendChild(script);
        loadCesium(async function() {
            // La tua chiave di accesso Cesium Ion qui
            Cesium.Ion.defaultAccessToken = 'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJhYjBlMWE4MS1lNWM1LTQzMjUtYTg0Ny1iOTBjMDlmMTQ1ZWUiLCJpZCI6MTgyNTkxLCJpYXQiOjE3MDE3NjkzMjZ9.6bCO4a_2zELu_jI-tzYrC6vWesZ3Ukfzu05zT8OSbnA';
            // Crea il Cesium Viewer
            const viewer = new Cesium.Viewer('cesiumContainer', {
                requestRenderMode: true,
                terrainProvider: Cesium.createWorldTerrain()
            try {
                const resource = await Cesium.IonResource.fromAssetId(2459318);
                console.log("Resource URL:", resource._url);  // Debugging the resource URL
                const tileset = new Cesium.Cesium3DTileset({ url: resource });
                tileset.readyPromise.then(function(tileset) {
                    // Manually set the camera to the tileset bounding sphere if available
                    const boundingSphere = tileset.boundingSphere;
                    if (boundingSphere) {
                        viewer.camera.flyToBoundingSphere(boundingSphere, {
                            duration: 3 // Seconds
                    } else {
                        console.error('Bounding sphere is undefined');
                    const extras = tileset.asset.extras;
                    if (Cesium.defined(extras) && Cesium.defined(extras.ion)) {
                        if (Cesium.defined(extras.ion.defaultStyle)) {
                            tileset.style = new Cesium.Cesium3DTileStyle(extras.ion.defaultStyle);
                        } else {
                            console.warn('No default style found in tileset, applying custom default style');
                            // Define a custom default style
                            tileset.style = new Cesium.Cesium3DTileStyle({
                                color: "color('white', 1.0)",
                                show: true
                    } else {
                        console.error('No ion extras found in tileset');
                }).catch(function(error) {
                    console.error('Error during tileset loading:', error);
                // Log any errors
                tileset.allTilesLoaded.addEventListener(function() {
                    console.log('All tiles loaded');
					viewer.scene.requestRender();
            } catch (error) {
                console.error("Error loading tileset:", error);
    </script>
</body>
</html>
Can anyone help me fix this issue?
I noticed that you are using an older version of CesiumJS (1.95). Have you tried using the latest version (1.127) to see if that resolves your issues?
thank you very much for your answer, that did the trick!
Bye
Andreas
