I tried tiling 3 different files on Cesium Ion coming from the same Blender file in different formats, but they all block at 9% in the tiling process.
Files aren’t even huge, they’re all under 1 GB.
Here are the IDs of the assets :
-3446302
-3446306
-3446340
I tested this tiling process on .glb files and .obj file. It comes from an elevation model file (DEM) that’s handled with BlenderGIS
Can someone help me out please ?
Thanks
I apologize that you are running into issues with your data being tiled. Unfortunately, you are running into a limitation in our old 3D Model tiler. You can try to re-run the above assets with the BIM/CAD option which uses a newer pipeline and should be more robust for tiling the data.
Ankit
Thank you for your answer. Unfortunately I get just one tile, that is a glb file (the same I had). There’s no point in tiling if at the end I get only one glb file, which I already had before even starting this process.
I did as you said and used the BIM/CAD option, and here’s the ID : 3450511
I just don’t get why it gives me only one tile without tiling into subtiles, with multiple LODs ? It’s a large piece of land, with up to 4 millions Vertices (that I converted from a .tif file to a glb file with BlenderGIS). Any hints ?
I read 27719, and it was suggested to check the data with the 3d Tiles inspector sandcastle using the asset id and adding in the associated access token
That’s what I did, and I zoomed in.
Confirmed, I only have one LOD, from my GLB file that has like I said, 4 millions vertices. I don’t understand
Can you help me out ?
I can provide the glb file if needed.
Thanks
There isn’t currently a way to force LOD generation on a model. Do you get a single LOD output for the obj upload as well?
One question based on the information you provided: if this is terrain from a tif file, Cesium ion accepts tif terrain file uploads that it converts to quantized mesh. Is there a reason you are looking to upload a glb? What is the final output you are looking for?
Ankit
Yes I get a single LOD output for the obj upload aswell. Which I don’t understand, like I said
Yes there’s also a reason I’m looking to upload a glb : I am making a Three js scene, where I want the user to interact and view the terrain, through tiles. Quantized mesh is a way, but it doesn’t fit my needs since the data ends on a globe at the end.
I’m using this : GitHub - NASA-AMMOS/3DTilesRendererJS: Renderer for 3D Tiles in Javascript using three.js
Again, with quantized mesh you can’t do as much as you can with other 3D Tiles.
I have no idea how I’m supposed to generate different LODs for an optimized solution on the browser. Currently I have one big mesh that is not tiled.
Do you by any chance, have similar cases of people that tried to generate 3D Tiles of a 3D model, and they didn’t understand why they ended up with only one tile ?
