Tilling stuck at 14%. Reality Capture upload
Asset number 2262805. Uploaded directly from Reality Capture. I didn’t do any advanced processing, just ran the mesh and added color.
While assets may take upto 24 hours to tile, in this particular instance this has been stuck at 14% percent because of a limitation in our current photogrammetry tiling pipeline. Unfortunately, this asset will end up most likely failing tiling due to the above limitation. However, we are in the process of creating and deploying a new tiling pipeline which should prevent issues like this from arising. Once the tiling pipeline is out, I will reach out to you to let you know.
Ankit
