After the project is opened for about one or two hours, the camera moves to a place very close to the ground and has not been loaded before. At this time, the fine tiles will no longer load. This problem exists whether in the editor or after packaging.
If the project is closed and reopened, the fine tiles can be loaded again, so I wonder if the token may have expired, but I have tried to specify the token I created on Cesium ion in the Cesium interface of the editor, but it still doesn’t work, and there is no LogCesium error in the log
UE version is 5.3, Cesium map is Bing Maps Aerial, Cesium plug-in 2.4 and 2.16 have this problem
Thanks for your reply. The map I use is “Bing Maps Aerial”, which is the one with ID 2 in My Assets.
I have tried calling RefreshTileset regularly. I have also tried resetting the Cesium Ion Server of Cesium3DTileset regularly, and calling the Open Level function of the engine regularly to re-enter the current level. All of them have the same problem.
Ok, I confirmed that token refresh isn’t working for Bing Maps, and wrote an issue for it:
