Using topography from Cesium as landscape
HI everyone, I want to start off by saying that cesium is amazing and is going to change map making in games from here on out!
Now what I am trying to do is take the topographical data and convert it to the editable landscape tool built into unreal 5, I was trying to just make a landscape plane and modify it to fit the topography but it is going to be grueling, tedious and generally terrible to do that.
Has anyone messed around where they can just convert it directly to landscape and just use that to modify/tweak it to make it useable for a racing game or other?
I want to make a sandbox racing game with real world locations and have very detailed areas that cesium is not able to provide at this time.
Also is there any way to get cesium to use the textures to apply to the buildings? and lots of missing buildings as well.
Bump anyone have any ideas?
Hi! I have the same problem with converting topographical data to editable landscape. Anybody please help!
I’m just spitballing here, but I think you could apply a custom material to the terrain that maps world Z position to black and white. Then set up a top-down orthographic camera and capture a height map that you could use to generate the landscape.
Hello!
I’d like to ask that is there any way to fit a landscape into cesium’s terrain surface (beside doing it manually)?
I’ve learned that currently its not possible to change the surface of Cesium world terrain because of how its programmed but is there any way to fit a landscape (with collision or offset or etc) to its surface? I want to use the current world terrain as a sample of where things supposed to go but i really want to make adjustments (add roads, hills + traffic etc) to the terrain.
Thank you in advance and happy new year!
Best Regards
Richard
Hi all,
Editing the terrain surface is definitely something we’d like to enable. We’re currently exploring this, and I’m hoping to have more information later on.
For now, please consider sharing your use cases for this feature here in this thread so that the team can gauge community interest in adding this to the plugin.
Thanks for using Cesium for Unreal!
-Alex
Hello!!
My use case is that I need to be able to create very large sized terrain zones for different levels of different locations…
In other words, I don’t need to have the entire World created, just different pieces of the world with a size that I determine and have each piece of the world chosen in a different scene.
Of course I need to be able to manually edit each piece of the World that Cesium creates, to add roads through splines, or to correct/modify certain parts of the terrain heightmap to my liking.
It would be great to be able to divide the areas created by cesium into different terrain tiles based on their size, so that we can load and unload these terrain tiles at runtime and maintain the resolution of the textures that Celsium creates for us. .
In short, the most important thing is that Cesium could create UE terrains using real world data with its included textures… Something like this Unity tool:
https://youtu.be/wNN8xdfm1_I
Greetings
My use case is Archviz, especially large exterior scenes. I need realistic topography, but also need to be able to paint materials and procedural foliage on the landscape close to the project origin. I currently use DEM heightmaps for my landscapes, add a Cesium dataset on top and hide the part of the tileset where i have the landscape. The small issue is that DEMs are using a projected CRS so the actual globe of cesium and the DEM don’t align perfectly. I also need to adjust the true north/projected north rotation for the two topographies to align better.
It would be great if there was an option to create a draped landscape using the tileset, specifying a desired resolution and possibly even applying a landscape material using the satellite images with the maximum resolution.
@Kevin_Ring @janine @agallegos - Happy Holidays to the three wise folk of Cesium Unreal :slight_smile:
Can you let me know if this PR: Generate navigation mesh on Cesium3DTileset by Project-PLATEAU-Admin · Pull Request #1044 · CesiumGS/cesium-unreal · GitHub addresses this thread?
I came across the PR in a post from @janine while following the other links above. I read the PR and see @Kevin_Ring commented on it and, of course @agallegos posted on all those threads to say “we’re working on it”
Sorry it’s a bit of a vague question. But, what’s the status of using topography from Cesium as landsape/terrain within UE? I know that I can mask holes into the Cesium content - but can I edit the terrain?
Thanks!
p.s. I’m most interested in tunnels and showing subterranean assets (pipes etc.)
No I don’t think 1044 addresses this issue at all. It’s been in the product for almost a year now, in any case.
There’s currently no way to edit the topography in UE. It’s something we’d like to do, but it’s far from straightforward and we don’t currently have a time frame for it. In the meantime, the closest you can get is this: create a GeoTIFF covering the area you care about, and containing the terrain heights you want to have in that area. I don’t know an exact workflow for that offhand, but I suspect a GIS tool like QGIS can do this. Then, upload it to Cesium ion as Terrain and choose Cesium World Terrain as the base layer. That will create a composite tileset that has your heights in your area, and heights from Cesium World Terrain everywhere else in the world. You can even upload multiple GeoTIFFs covering multiple areas.
In my opinion, this is the one feature holding back Cesium for Unreal and would be something just about every user would benefit from.
Understanding it’s a large technical challenge for the team, is there any way we could work on some type of unofficial tutorial or guide for doing this with QGIS or another method?
I’m more than happy to help contribute to this.
Hi @Scobel, welcome to the community!
Can you elaborate a bit on what you’re looking to do? That will help us prioritize the most important aspects of this (rather large) feature area.
As far as unofficial tutorials, we’re very happy to see you attempt to solve this problem using available tools, such as creating a custom overlay terrain in QGIS. If you try it and run into problems, let us know where you got stuck and maybe we can help. And if you got it working, a writeup of what you did in tutorial form would be very welcome on this forum. We also have been known to publish user-written tutorials right on our web site, with the user’s permission of course. Here’s an example of that:
Me and my buddy go out to a small town in the woods to hunt/etc. I’m attempting to take this area, and turn it into a game.
I was thinking I would be able to use the Origin latitude and longitude, then set like a perimeter distance from the origin, and export that section of the Cesium Terrain as a Landscape piece. This seems like an “easy” way to implement this.
As I want to make the map for the game a couple miles surrounding the house we go to.
So simply input the origin and how far out you want from it, and boom… there is your terrain.
Sounds good, huh?
Hi @cobra_the_cobra, welcome to the community!
I think your use-case a little different from earlier ones in this thread. For you, Cesium Clips might be a good fit. It would let you clip out an area from a larger tileset and save it as a single model, which you can then import into Unreal Engine (and edit using Blender or other modeling tools, if necessary).
The only problem is you’ll be limited in which tilesets you can clip. Notably, Google Photorealistic 3D Tiles doesn’t alow this. It’s a legal barrier not a technical one. If you want to use the Google tileset, the only available option is streaming.
hey im new here and came across this because i’m also wanting this feature. my use case is that i want my game/project to take place in the city i live (Lincoln NE), and i’ve found that when i move my pawn character around the google photorealistic 3D tiles, its all jittery; at first i thought it was because of the cesium default camera, but later i realized/figured that its the tiles themselves. i’ve tried to find a work around by getting heightmap data from other sources of the location i’m wanting, and then converting that into an unreal landscape, but that doesn’t give me the results i’m wanting, because the landscape doesn’t exactly match up with the tiles, which i’m using as reference for where things are located such as roads, buildings, trees and ect. i’ve also tried to use the clipping feature, but for some reason it won’t let me use the cesium world data, only certain data assets that i don’t need/want
Hi @Jello, welcome to the community!
its all jittery
Can you elaborate on this? Are you saying the model is actually jittering (moving) around the screen? Or are you just saying that the quality of the model itself isn’t as good as you want?
Have you tried Unreal’s GeoReferencing plugin? It might help here. Maybe!
Google’s terms of use unfortunately forbid clipping.
You can clip Cesium World Terrain. And Sentinel-2 imagery. But unfortunately not Bing Maps Aerial imagery, for the same reason.
so i’m using the GASP as a base, and i have two projects, one in first person and the other in third and first person, and its especially noticeable when in FPP; it looks essentially like as if i had enabled camera lag on the spring arm component, but i made sure to check and i know i don’t have it enabled. and as i was experimenting, i realized that when i place down an object like a square or make a landscape, it doesn’t do that. im thinking it might be because the cesium component is round, but im not sure
yes, essentially what i do is make a heightmap of the location i want from this 16 Bit Grayscale PNG Heightmap Generator for Unreal Engine and its very helpful because it gives what XY and Z to scale it to for accurate 1:1 scale, but anyway i’ve tried both importing the landscape first then the ion component, setting the accurate long/lat for the ion component, and making sure its correct, and in some places it fits well, but others it doesn’t, and i really might think its because the landscape is flat meanwhile the ion component is round
thank you sm for getting back to me, and i hope we can get to the bottom of this!
heres a video of my issue:
decided to just edit this post instead of having it as a separate reply
Piggy backing on this thread for any updates. My use-case would be ArchVis as well. Being able to drape a landscape on to a section of tile, and ideally capture the tile’s textures, would make projects I’m working on a breeze. The landscape tools at that point would be great for editing the topography – for example, adding a canal, easement, or razing a property, while keeping surroundings geospatially accurate. I’m currently doing a lot of workarounds with CartographicPolygons and model edits in other software, which takes a lot of time to sync up. BryceKaufmanTPS’s idea seems solid, just not sure how to go about creating a BP that can export a heightmap, and if that orthographic view would even return a heighfield/heightmap that retains the WGS84 curve.
Hi @Jello,
I can’t really tell what’s going on in that video. The first thing I’d check, though, is that “Enable World Bounds Checks” is off in your level settings. See step 3.2 here:
Hey Kevin! I want to ask if I could change/alter the Cesium tileset {The Cesium World Terrain} with the help of geometry scripting to create ground craters? Is it possible?? Also, Is Cesium Tileset a dynamic Mesh??
