When you restart Unreal, csv file data disappears.
I did the tutorial above and I finished it successfully. But when I restart Unreal, the csv file data disappears, so why is that?
Hi @xkfahdnjem1010,
I’m sorry that you’re experiencing issues with the tutorial. I’m not sure what could be going wrong off the top of my head, but I’ll try to reproduce the error when I get a chance.
I’ll start with a simple guess. When you upload the .csv file, do you see an asterisk on the asset? For example, when you edit a material in Unreal, it will look like this:
Usually this asterisk means that the file has not been saved. When you do successfully save the asset, this asterisk will go away.
Could you confirm for me that this is what you see?
It was a compile problem. I solved it.
