CZML Live Stream Data
Satellite is glitchy/jumpy when ingesting CZML data into Cesium - see attached video
I’m just going to focus on the CZML parameters below. If I missed anything that maybe important, please let me know. I set the availability interval for a quite a while.
I am also sending this CZML packet data below every time the external data is being updated which is approximately every 1 seconds.
Clock.currentTIme = currentTime
Clock.Step = “SYSTEM_CLOCK_MULTIPLIER”;
Clock.multiplier = 1;
Orientation.interpolationAlgorithm = “HERMITE”;
Orientation.interpolationDegree = 3;
Orientation.referenceFrame = “FIXED”;
Orientation.extrapolationType = "HOLD ";
Orientation.epoch = Ces_rt; (**This is just the start time of the availability interval)
List dbQuat = new List();
dbQuat.Add(ATD_QEST_CBI2BDY0);
dbQuat.Add(ATD_QEST_CBI2BDY1);
dbQuat.Add(ATD_QEST_CBI2BDY2);
dbQuat.Add(ATD_QEST_CBI2BDY3);
Position.interpolationAlgorithm = “HERMITE”;
Position.interpolationDegree = 3;
Position.extrapolationType = "HOLD ";
Position.referenceFrame = “FIXED”;
Position.epoch = Ces_rt; (**This is just the start time of the availability interval)
dbPos.Add(EPH_POS_CBIX);
dbPos.Add(EPH_POS_CBIY);
dbPos.Add(EPH_POS_CBIZ);
**When I add a time-value with the quaternion and position data, the Cesium animation does not seem to jump but the satellite lags behind significantly.
Would like a smooth transition in the animation when ingesting live data into Cesium.
How does the live flight tracker accomplish this?
Please let me know if you have questions - thank you!
Chrome: Version 71.0.3578.98 (Official Build) (64-bit)
Cesium 1.52
Cesium_Video.mp4 (1.09 MB)
What is the correct way stream almost real-time data in regards to the czml JSON parameters? Did I make a mistake in setting those parameters?
Thank you!
To have smooth transitions the next data point must be available to Cesium before it is applicable. Failure to do so forces Cesium to jump to the new point to maintain the “realtime” view because the new data is actually in the past. You can either have your source generate data slightly in the future if this is a simulation or run the Cesium app on a time-delay.
Hope that helps.
Scott
Hi Scott,
Thank you for your help.
Some questions:
Would I need to update the currentTime property in the first CZML packet continuously?
Would I need to update the time-tagged Position and Quaternion and or the Position/Quaterion.Epoch in the second CZML packet?
Thank you!
