I HAVE DOWNLOADED eCLIPSE EDITOR AND WHEN INSTALLING IT, THERE WERE LOT OF TOOL PACKS. CAN SOMEONE SUGGEST WHAT IS THE RIGHT TOOL PACK NAME PLEASE CAUSE I HAVE INSTALLED ECLIPSE PHP NEON AND COULD THAT BE THE RIGHT ONE? TXS
I assume you saw Eclipse in the Getting Started Tutorial. Admittedly, that’s pretty out of date, The Cesium developers use WebStorm for the most part, which will be much quicker to set up!
Gabby
Hello Gabby,
Thank you, I have done it with Notepad ++. Thank you.
Best Regards,
Yasaswi
